I just bought a two story property with solid wall construction. I dampproofed the entire ground floor with tanking slurry two weeks ago only found out today it’s the worst thing you can do to a solid wall structure. Due to thermal expansion of bricks, cement tanking would crack which comprised the damp proofing also traps moisture in bricks! It could slowly erode the brick and mortar. I shot myself in the foot dramatically
Can I get away with it? I am intending to keep the property around 10-15 years.
Or should I spend more money to strip it out now.
My mind can’t take it if I have to do the stripping straight away.
Help!
Thank you
Help!
Thank you
