cedrichn
- North London
Good afternoon all,
Since a year now, we are proud(ish
) owners of a ground floor flat in a Victorian House in North London, with my fiancee. I am a mechanical engineer, enjoy working on my cars, but I am a real beginner for DIY inside a home
Apologies for not using the correct terms...
The flat is a 2 bed, with damp in one bedroom. After removing all the layers in this bedroom (carpet, insulation, wooden boards, wooden beams, tarmac on tiles, small concrete-ish slab), I am back to the soil. I am now 99% sure that the humidity was due to the soil (or aggregate) being higher than the damp course in the walls (tiles): I can see the bricks under the tiles being humid, and the one above always dry. I now digged a lot out, and I wonder:
- How much deeper do I have to go?
- What layers/structure to go for? I read sand + modern DPC + concrete slab. Then, we would like wooden floorboards to match the corridor (all the flat is on suspended floorboards, except this bedroom)
Also, while digging, I found one rotten beam... I am not sure if it is the end of the beam holding the suspended floor from the corridor (on the right of the picture), or holding the internal wall, or a mix of both. I remove the crusty bits, and it looks like on the picture at the moment. What would you advise me to do with it?
Thanks for your help
Regards,
Cedric
Regards,
Cedric
