ElectronicFur
- Monmouthshire
So after ripping up the flea-ridden carpet, I found underneath it a wooden laminate floor, underneath that an underlay of some sort, and underneath that plastic membrane, and underneath that what appear to be the original flagstones.
This room smelled damp, the walls were damp with peeling lining paper, and the corners of the wooden floor looked damp.
So mystery of the damp is solved, as it appears the moisture could go nowhere but the walls. But the damp wood has attracted a wood eating beetle of some sort. It mainly ate the top layer of the wooden laminate, the bit on the edges underneath skirting. But also some skirting board. The flea spray at least killed the beetles I have found.
I'm started removing the wood flooring and plastic today. There is a skirting rail attached to the main skirting board, when the wood laminate was installed, and I will obviously remove this rail. But should I replace the main original skirting board in case it has larvae in it, or let it all dry out, and they will no longer be interested in the wood?
