Hi All
I'm finally getting round to replacing our 1970s/80s bathroom with something more appropriate to the age of our house next weekend. Fitting the tap is causing me a few questions because I'm not familiar with the various dimensions of pipes/connectors/etc as I don't know the age of the replacement taps and have lived in different countries for the last few years which all have different diameter pipes to UK ones so please forgive my ignorance.
The sink tap that I'm installing has a single block into which the hot and cold pipes are connected separately via male, brass, threaded, screw-in connectors each with an external dimension of 12mm and an internal dimension through which the incoming water flows of 8mm. Each connector is soldered onto a length of copper pipe that looks to be 10mm in diameter (if that makes sense).
I'm hoping there are Speedfit connectors or similar that I can pop onto the 15mm hot and cold inlet pipes and that will then screw into the tap block to form a watertight seal. I've found a pair of these on eBay that are "SpeedFit Flx48 12mm X M10 Flexible Mixer Tap Hose (pair)" Would these do the job for me? Here's a link if it helps...
https://www.ebay.co.uk/p/1762752522?iid=303247687073&chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=303247687073&targetid=876487124366&device=c&mktype=pla&googleloc=9045301&poi=&campaignid=9441121590&mkgroupid=95891581676&rlsatarget=aud-629407027625la-876487124366&abcId=1140496&merchantid=6995734&gclid=CjwKCAjw4KD0BRBUEiwA7MFNTYsCWnCdmwhTZr7bg-4MXk9Z0QcGFkpsjMcadOamuBh8xonB1X_SixoCueoQAvD_BwE
I genuinely appreciate any help.
All the best
All the best
