Craig89
- Shropshire
Hello all
I am coming to the end of plumbing my property but I have a question regarding the draining of the radiators/central heating system.
All of my downstairs radiators are fed with a flow and return that drop down from the ceiling (pretty standard I'm sure for many heating systems that have been installed in period properties over the years, especially those with solid floors). If I install a drain that goes outside lower than all the radiators will it drain the entire system by some sort of siphon effect or will water still be stuck in all the downstairs radiators and pipework?
The alternative is to fit a drain at each of the downstairs radiators, which I'm not against doing, but if one on the outside will work then that would be a nicer solution.
Thanks, Craig
Thanks, Craig
