Athers1971
So, our attempted purchase of our 300 or so year old Grade 2 listed house is going very slowly and hitting snags
Our mortgage lender had a valuation of the property completed (an actual inspection, not just a desktop or drive by) and the valuer has been unable to provide a valuation figure and therefore confirm the property suitable as security.
We have commissioned a damp and timber report from a local PCA member as this was the only way to proceed with our lender, we have received this report today. The timber report is as expected, with a quote of £2,800+VAT to treat all internal timbers for..
The damp report is a little more controversial. The Specialist has made a comment that chemical injection DPC are not permitted (?) in listed properties. His observation was as follows:
And recommended remedial measures:
The quote for the remedial works is £22,390 + VAT for re-plastering as defined above. This is basically for every wall on the ground floor which has 2/3 reception rooms, kitchen and utility.
So, we sending these onto the mortgage lender to see if we can get the mortgage sorted, but I am concerned about the suggested solution in respect of the damp.
Also, he was unable to do anything with the floors:
Any thoughts on our situation? Should we get a second damp report now, or wait until we have actually bought it? I'm a little worried that the mortgage lender will force us to do some works that aren't in the best interest of the property.
Thank you.
Valuer has marked the property as unsuitable security & not readily saleable with the following comments -There is damp to the walls, and chimney breasts and signs of wood boring insects to a number of the exposed timber, beams and lintels. A report on the whole property, including loft space and sub floors, is required from a Property Care Association damp and timber specialist, with all required work to be carried out to Property Care Association standards. Given the age of the property and its Grade 2 Listed status, no valuation can be provided until I have seen the requested reports.
active infestations of wood boring beetle in the form of common furniture beetle to numerous oak lintels, floor beams, to ground floor rooms also wall panels and floor boarding as well as floor beams and lintels to 1 st floor rooms.
On our recent inspection, I was able to establish high levels of moisture to those walls identified on the supporting ground floor plan. Levels and profiles of moisture in this instance indicate that those walls are affected by rising dampness, our recommendations follow accordingly:
Due to the levels and heights of moisture rise to those ground floor walls affected by rising dampness as defined on the supporting ground floor plan, internally, remove the internal wall plaster full height from floor to ceiling and remove waste from site. Re-plaster internally using a 8mm dimpled plaster membrane fixed to the walls with in the mortar beds using mechanical cob plugs, the membrane should terminate slightly below the solid floor to enable any residual moisture to naturally seep to ground. Once the membrane has been completed plaster over the membrane with hardwall backing plaster and hardwall skim.
Internal ground floors are of a solid construction with either tile or laminate floor covering, 2 of the floors have been overlaid with chipboard timber decking board on timber battens. Unfortunately moisture profiling of the floors could not be undertaken and as such we cannot report further.
Thank you.
