& Clementine the cat
- Bedfordshire
I'm wondering if I should replace the pipe from the water meter to the house. It will be a big hassle. I'm sure I have a leak on a spur that goes onwards underground to a different part of the house.
Making a hole for some fence posts they filled with suspiciously clean water at 1m depth. Is ground water normally completely clear when you find it?
t's a ead pipe to the house.
