Dear all,
On our ground floor we've put plasterboard hanging ceilings up to cover the new electrics (and improve sound insulation).
I know lime improves air quality, but since there's plenty of original lime plaster elsewhere in the house... Is there another compelling reason not to use gypsum plaster to skim the plasterboards?
Lime seems really expensive here in Germany, and I thought if we make a saving on the ceilings we wouldn't really notice the difference. Am I wrong?
Many thanks,
Ben
Is it worth using lime plaster on (gypsum) plasterboard ceilings?
Re: Is it worth using lime plaster on (gypsum) plasterboard ceilings?
I have done one ceiling here with plasterboard topped with lime. The key is to use a grit primer such as FeBond Blue Grit or similar (Baumit DG-27 is often mentioned here, but darned expensive). Mixed my own plaster from lime putty & ground marble - Unlike gypsum plaster, it doesn't go "off" and remains workable for much longer.
With gypsum, I struggle to get a good finish, so would probably get a professional in to do a whole ceiling.
Interesting. That would be my cost saving gone then, paying a professional!
In short, no, not worth it, just slap normal plaster on.
Just skim the board with something forgiving and a reasonably long set time, and you're good to go. Slightly heretical but I've used a single coat of Gyproc Easifill 60 when skimming plasterboard ceilings and it worked great, and has 60 minute working time per batch you mix up, and you can do the first watered down coat of paint within a few hours of finishing.
The Easifill is quite "fat" so nice to work with IMO, just dont faff about too long.
Haha ok, nice one!
We used Gypsum plaster on our celings upstairs but I didn't want a flat 'new' look finish. So, our plasterer did what he called a 'rubbish' job. The finish gave us a slightly undulating and uneven surface with trowel marks which, now painted with a flat emulsion, blends really well with the lime plaster walls.
Hope this helps!
Hope this helps!
Who is online
Users browsing this forum: RBailey and 4 guests
