overlander matt
A bit of a random topic - not really period property related but given the knowledge and experience of the contributors here, I thought I would ask. What should you look for when buying carpet? It's a subject I know very little about and generally I've ended up with carpet that has not worn very well after rubbing a few samples in the carpet shop! Has anyone got any tips for buying carpet?
We'll be laying them on floor boards - I believe it is common to line the floors with hardboard sheets before fitting the underlay. I've often heard it said in the carpet showroom that you should buy the best underlay you can afford. Does anyone know a good brand/type to go for?
Any suggestions would be most welcome. Thanks!
Matt
Matt
