I’m hoping some experienced members can ease some of my anxieties about this subject!
We’re adding an en suite to a room which has previously contained no bathroom / plumbing. One wall will be external facing, and is currently stripped back to red brick. The floor is suspended timber (first floor level).
Our plan was to use insulating plaster to the external walls (calcea), and the internal dividing studs will just be standard dry wall.
The dilemma occurs when planning the internal finishes... tiling, wet room design etc. Some form of waterproof ‘tanking’ is almost always specified, in the shower area in particular. These are of course not breathable, and our shower area will be in contact with the external wall. Surely applying non brethable layers to the insulating lime plaster is counter intuitive? Would interstitial condensation not occur behind the tanking layer? In that case, would you create a stud wall that will hold the tiles with a cavity between it and the external wall?
Alternatively, I know Tadelakt and microcement are thought to be breathable.... can these be applied directly to the external facing, lime plastered walls?
Any advice on adding en suites to old buildings would be much appreciated!
