Hi there everyone - I've just taken ownership of a 1920's mid-terrace, and as part of the survey the crumbling plinth and some rising damp was noted. Upon getting a very recommended damp/timber preservation company round to map the house for issues, among many other things, damp across a lot of the front of the house was noted. This is combined with a rotting joist in one corner, as I had already lifted the floor in this area using existing cuts in the floorboards (most likely for gas fire installation). Their suggestion was to clear out the aerial cables that had been routed between the garden wall and the house (see pics), clear any debris from that gap, and they also pointed out that the whole house had been repointed with cement on top of the original lime. The damp joist though they thought was caused by a failure in the slate DPC at some point, and so along with adding a vertical DPC to stop anything going into the party wall from the front, they're also going to inject a new DPC when they replace the joist to make sure it's continuous.
Since that survey, the plinth has crumbled even more and now I'm just confused. The damp company told me to get the shingles away from the plinth, which I've done, but it's revealed a concrete "border" all the way around the front. I've tried looking for the original slate DPC, but even where the plinth has come away I can't see it (although some higher layers of brick are obscured by the cement mortar). I was hoping to install a french drain at the front to keep as much stationary water away from the plinth as possible, but now I'm confused as to whether the plinth itself is the problem. It appears original, as it's got cast iron airbricks and is identical to the plinth and airbrick setup next door, which is in "more original" condition than my own property. Behind it is also yellow bricks like at the back of the property, rather than the red of the rest of the frontage. One slight difference is that over the years mine has been painted black many times, whereas next doors is "naked". The plinth and concrete border are both pre-1960, as the house was my fathers growing up and he remembers both features from when he was young.
Could it be the culprit for bridging the DPC, or is it potentially something else? And how can I prevent doing all this work inside on the joists and DPC to end up fixing nothing by still having something causing an issue? How do I fix the plinth, if it's keep-able?
I've taken as many photos as I could (thumbnails in post, full-size as attachments), so hopefully one will provide some insight - but I've never done anything like this before, so I really don't know where to start, I hope my many questions are okay!
