malcolm
& Clementine the cat
- Bedfordshire
Linseed will take weeks to dry in these temperatures. You are probably better off with one of the other paints mentioned.
Linseed now?Thanks for the two quick new resposes (Me! and Feltwell). I'm sure what you write is correct: best to dry linseed oil in the ultra violet light, in warm dry weather. Unfortunately I have to do it right now, in the depths of winter when it's very cold and you cannot rule out the occasional shower (even when the weather forecast says otherwise)
Yes, as with anything online someone is always watchingI wonder if anybody will see this, as the thread is getting old
And some KitKats with strong tea or coffee, this time of year a creme egg or two once the job is done*A revelatory tool tip might be just what I need.
Thank you, if barge boards can be cool, those are. Because of the shake one of those trefoil bits was a scarfed in 'repair' from new. I've replaced two including that one, and all the ones on the south west elevation now have a long brass screw up through them to hold them together. The same barge board design is on the other end of the house, but it's like new since it doesn't get strong sun or the prevailing weather. For the sanding disk I'd say flat surfaces, they're extremely effective, with care leaving a beautiful finish on the bare wood. Definitely not something to be used anywhere near glass!Hmm, thanks for the tip re the Norton paint stripping wheel. I am losing the gumption to continue stripping my windows, though I will persist. A revelatory tool tip might be just what I need. Is it okay on fiddly bits, or just flat surfaces?
Barge boards look fab!
I was so impressed with the evident capabilities of the epoxy filler that I applied the hardener to the exposed rafter and skimmed it with the filler to true it up where it had cupped and cracked. Such an approach wouldn't last five minutes with polyester wood fillers! I have no connection to 3C other than as a very satisfied customer, and hope my experience is useful to others.
It's called PPEM (Period Property Entropy Malaise) - an incurable ailment that afflicts people who buy old homes with their eyes wide shut. The health warning message - seldom publicised by estate agents and conveyancing solicitors - includes an oblique reference to the San Francisco, Sydney Harbour and Forth bridges and something about paint.*or as done as it’s going to be, I’m learning that period properties are never ‘done’ done![]()
