If you put the steel on its side it holds the bricks better![]()
All of the power sockets upstairs were undersized in my house, they used the same wire you're supposed to use for the lights1930s semi -
We’ve found a steel that at some point in the past has been put in the wrong way around. Our builders said they’d never seen anything like it. It’s holding a brick wall above it.(What would the logic/situation of sticking a beam on its side ever be?
Fitted wardrobe in the way of your electric wiring? No problem - just send it straight through an outer corner of said wardrobe straight through from top to bottom ceiling and floor
Dread to think what else is coming when we start renovating properly![]()
We have a very large inglenook. A previous owner had fitted a long fluorescent tube light behind the bressumer beam but, rather than connecting it to the lighting circuit, they took a spur of the nearest power socket. Our consumer unit (actually fuse box at the time) had separate fuses for the lighting and socket circuits so if there was ever a good reason to turn all the power off before you start work on something, that was it. Thankfully our electrician found it before we found out the hard wayAll of the power sockets upstairs were undersized in my house, they used the same wire you're supposed to use for the lights
Mesh in the render... so they did a thorough job... are you complaining that it wasn't bodged?OK lads, we need to core drill through this wall. But boss we can't get through - the mesh behind the concrete render ...
That hangs perilously close to the border between bodge and genius
Re-cyling Effort = 10/10
Bodgers were highly skilled furniture craftsmen and wood turners primarily from the Buckinghamshire area. I consider myself to be a bodger (in spirit, in that I do an inordinate amount of intricate wood fiddling, not that I am highly skilled) A boDGE would be a highly skilled and professional bit of carpentry...I'm at the moment having a brick arch above a sash window repaired. It had previously been repaired (about a year ago, instigated by the previous homeowners) under an insurance claim. When the builder I've employed started taking it apart it became apparent that the whole lot had been stuck together with no more nails and pointed with cement!!! The builder said it had been a while since he'd seem such a bad bodge. What other nonsense have people encountered??
Perhaps an improvised 'cleat' - as used on boats - to secure a rope from above for say a loft ladder or stabilise a heavy/awkward load on the stairs below?You mean THE Worst!?
THE worst is this!
(It's on a landing between floors and nothing can be hung, just slides right down. I'm suspecting some "secret" use for it but my IQ doesn't stretch. I've left it in place for now, it's probably structural)
Makes me seethe when I see the slots in screws not lined up orthogonally.You mean THE Worst!?
THE worst is this!
