William
- Winkleigh, Devon
Hello everybody,
This looks like an interesting forum for period property, so I’ve registered and this is my first post, so hello.
I’ve undertaken a variety of work on previous period homes but, for the first time, I’ve moved to a cob house so I find myself on a new learning curve and I probably have more questions than answers - ‘hope that’s okay! I’d also be interested to meet people, see work or even problems associated with cob property near where I live, in mid Devon.
So my first question is how does one ‘start’ a perpendicular wall, of conventional construction, up to a cob wall? I’ll soon be demolishing a small porch (which is so badly constructed that it actually takes some believing) and I plan to rebuild a similar sized addition using either conventional brick or maybe oak framed construction. I’m not listed.
With conventional modern construction, where one would start a wall from stainless wall starters, bolted into the existing wall, that doesn’t strike me as being a viable option when coming off a cob wall so can anyone shed any light?
I did wonder whether some kind of plates or mesh, alternating horizontal and vertical orientation, maybe 50cm apart, built into the new construction and lime rendered into a reasonable depth slot in the cob might be appropriate. If it went say 30cm into the cob, surely any forces concerned would at least to some extent, be less of a point load and more of a turning force, which I’m guessing might work?
I’ve looked around and haven’t found an answer and surely there must be a well-tried, good practice method – can anyone advise?
