Good afternoon. We have moved into a ~1890s cottage in a Cheshire village and I'm looking for some advice on how best to deal with a damp issue. There is a persistent damp area (black mold, flaking paint) on the living room wall behind the skirting and just above it, running from beneath the window toward the corner (see first image). Note that the floor is hardwood on top of a concrete base and is about level with the lowest extent of the white render.
The mortar between the bricks below the render has degraded in a few areas (see close up) and we discovered (after scraping away the pebbles) that there is a stone/concrete base under the pebbles that goes right up to the wall (with a partially degraded layer of mortar at the join) which is possibly hindering drainage. I should also mention that the previous owners had a chemical DPC injection done on this wall.
My main questions are:
- Which material should be used for repointing the exposed bricks? (I am unsure whether they were previously done with lime mortar and whether there is any benefit in using lime given the use of chemical DPC)
- Can the same material be used to repair the join between the wall and base?
- We are thinking of landscaping the front drive - would it be advisable to remove this concrete base (and e.g. install a French drain) or could this damage the foundations?
Any comments or advice are greatly appreciated. Thanks.
