prodical
- St. Albans
In about 3 weeks I will be lifting up all the existing pine floorboards in order to add insulation between the joists (using the system devised by ecological building systems). So this is a great opportunity to restore & repair the existing pine flooring which is looking rather crap. Photos don't do it the misjustice it deserves.
My initial plan was to run all the lengths through a thicknesser/planer. BUT, I lifted 2 boards this week and measured their thickness, they are only 15mm (ish). If I was to plane or sand these it would make them even thinner. In fact, if I put all my weight on some boards they flex in between the joists.
Question 1: Are these boards a total no go and need full replacement? What is the minimum thickness before I start restoration so I know which are no good?
Question 2: I would have liked to place all the boards back down with zero gap between them, but despite their age this is probably a bad idea. Would a 3mm gap between boards be sufficient for seasonal expansion contraction?
Question 3: Screw recommendations! Ive decided to go with screws, but I don't like the famous SPAX flooring screws as they are silver and their head is rather wide. Would Tongue-tite TX screws be suitable? Would they have enough purchase on the soft pine? I like how their heads are narrower so can be burried/ hidden easier.
Question 3a: Would screwing through existing nail holes be a no go?
