Hello
I have attached some photos of the rear of my cottage. It's 17th century timber frame. Unfortunately it has been repair with cement rendered (previous owner(s).
I recently had the exterior painted and the decorator brought this area to my attention. It's not the complete wall but an area of approx. 1.5 meter square. I don't know if you can expand my photos to see the problem. The photos are not great because the wall is at the rear of the property and close to the boundary wall. Anyway, I was advised to consider having all the render from this elevation removed, boarding applied, followed by Lime render. I have one quote so far which is:
Install scaffold, remove cement render, fix 25mm wood fibre backing board, lime render over wood fibre board. Apply breathable paint. Cost including skip but not including VAT is £ 7000.00 so £ 8400.00. Also this does not include replacing anything that may be damaged underneath. It's a lot of money, any comments or advice would be greatly appreciated. Thank you in advance.
