Hello!
We are right at the beginning of a project, and while we waited for replumbing, etc etc, we have removed cracked cement render from the gable end. This was on top of brickwork, which itself is the external wall to an internal stone one for two of the three floors. The house is a real hodgepodge.
We are in Dorset, and most of the house walls are just thick stone walls, but both gable ends are externally brickwork, I'm not sure why, but I suspect it was pretty crumbly at some point and the brick held it up.
Okay, getting to the point, some of the brick is okay, some of the cement is still stuck on as I'm too scared to chip it off - and might try gently by hand. I would ideally like it to still be brick, as it is much softer and prettier than the render. So might it still be possible to repoint it? And keep it stable and watertight?
But we are thinking about potentially, if we can't repoint it, of a lime 'slurry' or a lime render.
Here are some pictures from right at the beginning and a couple of days ago.
Thank you so much for any advice or thoughts!
