Mike_England
Hi all, hoping for some guidance on lime pointing… I’m in a early Victorian terrace and just had the chimney stacks repointed, it’s grade 2 listed so lime mortar was required
After a couple of days I’m seeing hairline cracks mostly at the perpendicular joints, pretty much every other brick.
Should I be concerned ? The contractor states that any cracking under 2mm is considered normal so nothing for them to address
But should I be concerned?
The contractor has used natural hydraulic lime NHL3.5, building sand and I believe Portland cement in the mix. Not sure on ratios
Attach a photo
Thanks for the help
Mike
Attach a photo
Thanks for the help
Mike
