we’re at that stage of getting to putting stuff back into our project (mostly!) - most first fix plumbing is there, we know what size and where rads will go, but… mounting mechanisms are currently throwing me this week’s curveball that I haven’t allowed enough time for!
Rads for me fall into two camps, ones that are self supporting and stand on the floor and those that need to be hung via brackets on walls.
Ideally it feels like I need the love child of both, top mounted brackets onto a timber rail and supporting feet to go on the floor.
I can only do cast free standing downstairs where weight can be managed safely on solid floors. Everywhere else, will need to be wall mounted or light enough to free stand.
My challenge is that mounting brackets need to be in set locations and are usually immovable on the rad, which doesn’t align with our timber frame. I can’t get two adjacent posts to work in most settings, and would only be able to mount on one horizontal rail, near the top of the rad but nothing lower down.
There are some steel (relatively lighter) column rads which have clamping brackets which can be moved (a bit) but I don’t personally trust the whole weight of a full rad being pulled into the wall.
So, how have any of you with timber frames dealt with rads?
Of course, it’s doesn’t help that we need to reach pretty hefty Wattage requirements given the volume and construction of rooms, which means heavy rads or more thinner ones…!
