my_name_is_slim_daisy
Hi everyone,
Good to be here. After googling around for help with period properties I stumbled upon this forum, and looks like the community is active, friendly and helpful!
I recently purchased an Edwardian house - built around 1925 I believe. I'm trying to get it water tight so have done a fair bit of roof work which I was rather pleased with. Then it rained bucket loads for the first time since I moved in, and I realised the gutters are probably made from Ikea plastic colanders.
I've been advised to get deep-flow gutters as it holds a lot more rain water. I've been doing some research on what the process is to have new gutters installed and I was hoping you might be able to chime in with anything I may have missed. Any advice would be greatly appreciated
- To measure the "fall" (i.e. decline?) for the gutters, this is the proposed calculation/method: use a fall of: 1mm:800mm. Measure the total length of fascia that needs guttering and divide it by 80. This gives the total fall over that distance. Fix first bracket and run a string line from it but lower at opposite end according to your fall. Fix brackets to fascia at correct spacing so and clip gutter in. Does this sound about right?
- Place a gutter bracket every 800mm.
- Use rust proof screws.
- Do I need to prepare the fascia boards e.g. filling in holes, primer etc?
- Is it sufficient to use a ladder or is it best to hire a mobile platform / scaffolding? I'm happy to use a ladder if it's enough to get good results.
- At what distance should I place each union joint?
- Anything else to consider?
- Quote 1: £2,160 + VAT. Replacing gutters and using existing downpipes. Not specified whether they will use a ladder or mobile platform/scaffolding. Lots of good reviews on Which.co.uk and other sites.
- Quote 2: £5,000 + VAT. Replacing gutters and downpipes. Erecting scaffolding to front, side and rear elevations. Good reviews on Which.co.uk and other sites.
- Quote 3
: £1,000 + VAT. Replacing gutters and downpipes. Sounds like they will use ladders to get the job done. Found via recommendation. Decent google reviews.
