JonH
- F75iyuf75iyu1*
I’m looking to insulate a vaulted ceiling (which used to be loft space) to create height in a bedroom and ideally expose the roof rafters in the pitch.
The roof is clay tiles with a bitumen felt underlay. The apex roof rafters are approximately 100 thick. I’ll not sure what insulation method to use that maximises thermal properties without loosing the rafters or causing damp / condensation problems. I’m also unsure if I can insulate directly against the bitumen felt or if I need to leave an air gap?
Initially I was thinking of stapeling insulting foil to the rafters 25mm away from the bitumen felt to create an air gap and first layer of insulation then used insulated plaster board approximately 50mm think flush to the foil to create a second insulation layer between the rafters that can then be plastered?
Alternatively I was thinking 50mm wood fibre board insulation cut to fit between the rafters leaving a 25mm air gap and then limeplastering over the fiber board?
Any advised greatly revived!!
