Currently there appears to be 3 products which fulfill the breathability criteria for IWI for Victoria/Edwardian solid brick wall contructions on the market which can be fitted between studs applied to the walls.
Woodfibre seems a very popular choice on this forum and currently heavily inclined towards this option.
Would it be possible to have your opinions on the other 2 products please-- IndiTherm Hemp batts and Sisalwool batts in terms of how they compare property-wise to wood fibre and in particular any contraindications for use for these products for IWI.
www.sisalwool.com
www.roofgiant.com
Thanks in adavnce
50mm Insulation Slabs (370mm & 570mm width)
Packs of 50mm slabs for walls, floors or roofs. Natural, safe and easy to install. Order online and get fast delivery throughout the UK.
IndiTherm Natural Hemp Flexibatt Thermal Insulation Batts - 50mm x 570mm x 1200mm (Pack of 8)
IndiTherm 040 Natural Hemp Flexibatt Thermal Insulation Batts are a healthy, soft-touch and flexible insulation solution that...
Thanks in adavnce
