I've just had a survey done on a 1760's Georgian Property I want to buy.
Whilst the report is pending, they have shared the photos, and the worst part of the roof is attached.
As you can see, lots of slipped clay tiles, and all out of alignment (the other three sides look a lot better).
Long term we would like to convert the loft space (in 5 to10 years), so we want to do as little as possible with the roof in the short term.
Has anybody got any experience or know how realistic it would be to just replace the broken tiles and those that don't have nibs on them that have slipped.
I don't know how the tiles are currently held in place (nibs, wooden pegs or nails)?
The battens in the loft are dry and solid.
But you can't see the underside of the tiles due to the torching (layer of lime which unfortunately has a layer of cement on top of the lime).
Advice from the surveyor is we ultimately need the roof tiles relaying/replacing etc.
Question is, what can realistically be done instead to give us another 10 years?
Assuming a minimum touch repair can be done and then, if 10 years come and go and we don't do the loft conversion, if the tiles are still holding straight, then is there a problem to solve? If not, then does it really need the roof renewing?
