terrlor
- Warwickshire
Hey,
I've got old brick walls, they're plastered (original) but not level so want to use tile backer board over the plaster before tiling. Planned on using adhesive to level and screws with plugs & washers to manually fix
Problem is when I try to drill into the wall the plaster crumbles away and the brick either falls apart or the drill can't go through it (a guess that it's hitting small stones in the brick)
Anybody had this before and know the safest way to get the tiles on the wall? I don't have space to batten unless it was about 1cm, maybe 2
