As part of a multipronged approach to tackling my interior damp problem. I am looking to tackle my exterior height issue(two inches higher externally compared to internally), at the same time as improving my overall rainwater control(downpipes that flow out to groundwater in places).
You can see from the pictures attached, that the downpipe on the front/gable end corner just puts out to ground.
My hope is to dig a French Drain which lowers the external height back to original(a drop of around 200mm based on the Drain to the front of the house pictured), and run the downpipe through the trench to the working drain at the front of the property.
My questions are many, but I'll ask the priorities. Is this a workable plan, or is there a more obvious solution I am missing?
Thank you.
Thank you.
