I took a small section off, it felt dry underneath.Hmm. Interesting thread. Did you try removing any plaster internally to look at whether the dampness continued into the wall or was just on the surface?
Absolutely. My plan to is to go back to brick on the walls either side of the chimney breast, and lime plaster a base coat, then likely a woodboard with skim. I just didn't want to touch it until ruling out/fixing any ingress. I'll give it a week with a heater/dehumidifier on it to get it properly dry, then a week for safety in case any other causes come to the fore, then get onto taking it all back(including removal of the hideous concrete render underneath the gypsum!).It looks from your photos like gypsum not lime, therefore modern not historical. I'd be pretty surprised if that amount of water was condensation but have you considered taking more plaster off and maybe replacing it with an insulating breathable plaster, some lime hemp maybe?
This photo still baffles me but might just be my eyes. Anyway I have questions which you might not be able to answer but I’ll give it a go!
Hard to say to be honest. The crawl space is too low for me at 6 foot to get across without risking going through the ceiling!This photo still baffles me but might just be my eyes. Anyway I have questions which you might not be able to answer but I’ll give it a go!
Is there leadwork coming all the way through the wall into the loft space at the back?
What’s the thing coming out of the rafters that looks like a white pipe?
Is all the black stuff hanging down failed felt? Are the slates above it definitely good?
Those are a sort of 'double' interlocking concrete tile and that's the side joint between tiles that would normally be hidden, the 'side overlap' is much greater than it appears because of that. A self-respecting workman* would have cut them so that the top course under the chimney didn't stick out like that.some kind of 'fluted' material beneath the left most tile
The tiles look like Redland Mockbond, which are standard sized interlocking concrete tiles with a dummy joint in the centre to look like thinner slates.Those are a sort of 'double' interlocking concrete tile and that's the side joint between tiles that would normally be hidden, the 'side overlap' is much greater than it appears because of that. A self-respecting workman* would have cut them so that the top course under the chimney didn't stick out like that.
Looking at the earlier photos it's struck me that (due to the extension?) the roof is now asymmetric with not much of a pitch on the roof where the chimney is. That would increase the chances of leaks at the chimney flashing. Interlocking concrete tiles can go to shallower pitches than plain tiles or slates, but those shallower pitches would be not so good where chimneys are present. The design, workmanship and materials on that roof generally give me a bad feeling - more the sort of thing you might get away with, than good practice that's certain to work.
*I suspect that the shallow pitch of the roof means it can't normally be viewed from the ground.
A braver man than I!I think someone has to get up in that loft and have a look. I know you said it's too tight to get up there, but looking at the loft pictures, I don't think it looks too impractical. I know I've been in smaller loft spaces than that.
Thank you for this, it's really interesting as I always assumed they were just thinner slates!The tiles look like Redland Mockbond, which are standard sized interlocking concrete tiles with a dummy joint in the centre to look like thinner slates.
Depending on the headlap, they can go as low as a 17.5° pitch. As you say though, the quality of workmanship is in question.
Lack of a lead tray in stacks can cause damp issues nowadays when chimneys aren't used with open fires daily.
It's always a good idea to verify your exit route and method at almost every step of the way forward. In one section of our loft I can only go in on hands and knees but can only get out with an almost horizontal 'bum-shuffle' - inelegant and bruising.A braver man than I!
I'll take a look at how to do it safely, the issue is I can't get from joist to joist on my front, but it's too short for me to scurry along the top of the middle wall/around the uprights.
As an update, I have a chimney sweep coming on Monday.
Firstly to sweep the chimney, and secondly to replace the cowl and inspect.
