Hi all, I have a bedroom ceiling to paint. It’s about 4m x 5m.
It was freshly plastered and I added mist coat which went on fine, no peeling. I then did the first coat of paint, which was fine, only two slight patchy areas, and then my partner did the second coat last night and it looks absolutely terrible now that it’s dried. He tried his best.
There are patches absolutely everywhere and it’s very obvious in the light. I think i’m much better at doing this so I will do it, but I’m concerned that another layer of paint might cause a problem? Will it look uneven? What if i do it patchy too?
I’m worried that adding the third coat paint coat will cause a problems so I’m nervous about going forward.
I also noticed that painting in the direction of the light from the windows might be a bad idea? Should I do it the opposite direction , or maybe it doesn’t matter.
Also my neck hurts so much after painting the ceiling. Any tips?
Thank you
Thank you
