HollyBlue
- Warwickshire
Hello everyone,
I’m hoping for some guidance. I’m living in part of a medieval building in Warwickshire. Originally a Knights Templar preceptory. The official Historic England record dates the timber frame to the 13th–14th century, though local historians suggest parts of it may go back as far as 1152. The property is Grade II* listed.
At some point, some of the original beams were painted over with black gloss. The surface is now flaking and cracking, and it looks like the timber itself is cracking in parts. In some places the wood beneath feels soft or friable -Mostly shallow (around 1 mm), but up to 3 mm in a few spots. There are areas filled with plaster or modern filler, and a crude timber patch in one spot.
I’m not the owner, only a long-term tenant. I have raised the issue with the landlord and the charitable foundation that manages the property. Unfortunately, because this part of the building isn’t public-facing, there’s no intention to intervene.
I don’t want to overstep my position, but I also don’t want to neglect what feels like a small piece of history. I have very limited funds, but plenty of time and care. My only goal is to do what’s right for the beams. To stabilise, clean, and respect them.
I understand that any invasive work would technically require Listed Building Consent, so I’m not planning to strip, sand, or treat anything without guidance & permission. I’d just like to know what might safely be done at a tenant level to prevent further harm. I’d also be curious to know what the ideal solution would be, if the financial aspect wasn’t a consideration for the landlord.
I’ve attached photos showing the current condition. Plus two photos of an unpainted beam elsewhere in the building for comparison.
I’m entirely new to this, so any advice or reading recommendations would be deeply appreciated.
Thank you for taking the time to share your knowledge. Even a small pointer would mean a lot.
Jemma
Jemma
