anxiouscat
- Scotland
When I bought my house last year (Scotland, old stone cottage built c. 1850), the Home Report stated that "slightly elevated moisture readings were obtained at the bedroom fireplace". The fireplace in question isn't being used and hasn't been used for a very long time. It's on an internal wall. The other side of the wall is another fireplace (also unused) in the lounge. The chimneys are capped.
A specialist came around today and used a moisture meter to take readings (one of those meters you press against the wall, i.e. doesn't go into the wall). The meter read 99.9%. The specialist said it's common in these old houses for debris to fall down the chimney and pile up at the bottom (these were readings starting at the bottom, and going up roughly a metre). He said they would need to remove the plasterboard and clear away the debris, which was a quick and easy job. He got the same readings in the fireplace on the other side of the wall too.
But... those moisture readings left me wondering: If they're so high (the highest the moisture meter will go), shouldn't I be seeing evidence of the moisture/damp? The wall is dry, no visible signs of any damp.
(Not sure if weather makes any difference, but it's been rainy/sleety today.)
Is this right? Is there something going on behind the fireplace that isn't visible from inside the room?
