my_name_is_slim_daisy
I’m having a bit of trouble mapping this, so I’ve attached pictures. The flexible hose you’re referring to is the white plastic thingy or the black hose? As I’m writing this it seems you’re referring to the gold/brass thing?Close the two valves at the ends of the flexible hose (lever at right angles to the hose) (at least one of them should normally be closed). Unscrew the end of the hose farthest away from the boiler pipework using the metal "wings". The water left in the short section of hose will come out but it will be a tiny amount. Attach the hose to the can. Slowly open the valve on the pipework side. If no leak then pull the trigger to discharge the can. Once can is empty close the valve again. Unscrew the can. Reattach the filler hose to the water main side. Top up as needed. I don't think the can leaking is a high risk unless you are really cack handed at attaching the hose. If anything goes wrong just close the valves and seek help.
thank you.What make and model of boiler do you have? Was the CH system operating for several days before it was switched off to let it cool? Most combi boilers operate in the range 1 to 1.5 bar when cold quite happily. A reading of 1.3 should be nothing to worry about and does not typically signify a leak.
Chemicals can be added via a radiator - It is how I dose my system. I have a short length of flexible hose that will screw in to a capped bung hole with a funnel on the other end (something I cobbled together in the garage). Before adding chemicals, the system gets drained down partially. Less mess than shutting a radiator off and having to go through the hassle of balancing it again afterwards.Can sealer be added via a radiator? I wasn't sure about that.
A golden physical rule though is that the pressure will be greatest when the system is hot and lowest when its thoroughly cold BUT the lower pressure reading will also be influenced by external factors such as the ambient temperature indoors. As a consequence, any pressure readings you record and perhaps act upon should be based on observations taken only when the system is in full operation and the radiators are hot AND when the system has been switched off and allowed to thoroughly cool - but you must also remember that the temperature of the systems water may take several days to fall to its lowest value and therefore its lowest pressure (this is why some combi boilers refuse to start up after they have been left unused for several days).
You're very welcome. We all operate on a 'Pay it Forward' basis having been the beneficiaries of aid and advice from others in the past - you'll be very welcome to the club. Take care and Merry Christmas,Thanks everyone.
You've all been so helpful, I really appreciate it.
I think it's highly possible I am worrying about nothing. I just worry we are damaging the boiler and will need to replace in a few years when we already spent £4.5k on it (inc the ecotec vaillant, the labour and a tiny bit of pipe changes).
I can't believe how little I know about anything about houses!
I hope to be a different person in a few years and able to give lots of advice to people who need it like you all do on here!(I don't think you all realise how much your help means to us - thank you so much!)
Likely to avoid accidental contamination of the potable water supply with the tainted and treated water of the heating system.I wonder why such things are not fitted to filling loops?
Theres another factor that is, to my mind, seldom if ever taken into account. Like most other metals copper expands and contracts, as do steel radiators, and as they do the pressure on the contained fluid conversely increases or reduces. One would expect such changes to have only a slight effect but it could perhaps be enough in some installations to trigger a sensor cut out?That's a good point and quite possibly the reason for our pressure to drop below the boiler minimum after a period of disuse. But I think there's also something else going on because the pressure dropped too low a couple of weeks ago and required topping up again before the boiler would restart. This time, I was at home and noticed it after a few hours, even though the boiler had been operating every day since the onset of colder weather, so the overall system had certainly not had time to cool down to ambient temperratures.
Now that I can switch the system on/off remotely, these pressure drops have become a bit of a nuisance when I get home to a cold house (ok, first world problem!) so I've wondered about fitting a motorised valve to the filling loop, but I'm nervous of this as I can't remotely measure the system pressure and could easily over-pressure the system by 'blindly' opening/closing the valve. The other thing I've considered is fitting a pressure regulator within the filling loop.
Actually, we already have a pressure regulator limiting the incoming mains supply to the house to 3 bar, so I wonder why such things are not fitted to filling loops? I suppose it could cause problems in the event of an actual leak, but perhaps a combination of a motorised valve and a pressure regulator would work in terms of remote control? Hmm.
