Hi everybody I am trying to remove black suit after having opened up the builders opening in a chimney breast in our house. I have tried using hydrochloric acid to no avail and I’ve also tried oven cleaner which also didn’t really work.
I was told that a mixture of caustic soda water and wallpaper paste applied to the bricks and then covered with clingfilm and left for 24 hours would have a good effect.
I’ve mixed approximately 7 L of water with two 250 g bottle bottles of caustic soda and added a packet of wallpaper paste to the mix mixed it up until it was semi gel like I think it was a bit too thin to be honest, applied it to the bricks and covered it with clingfilm to stop the wallpaper paste from drying. I don’t care if it doesn’t work. I’m now absolutely paranoid that the wallpaper paste will dry and I won’t be able to get that off now.
Does anybody have any experience of such things with the paste dry? Will the solution remove the soot ?
Thank you
Thank you
