I submitted an LBC pre-app about 5 weeks ago 9so deadline for a response was a week ago). In it, I asked if wooden panelling from one room could be removed under emergency works. It's likely a 1950's retro-fit, it's rotten and is covering up some very wet walls that I need to dry out.
My surveyor agreed it is probably a late addition and likely to cover up problems rather than dealing with them.
I've held off starting this work as I want the nod from the conservation officer, but it's been five weeks now.
I've also chased for a response but received nothing.
There is no phone number, just an email address.
Realistically, how long do I wait before just cracking on? The building is wet and needs to dry.
On a similar line, I also need to sort out a heating system downstairs. All included in the pre-app. Mainly fitting radiators to an existing pipe network. Again, I've not started doing this work as I want to know if it needs consent or not. But we're in the middle of winter now and have no heating downstairs so it's a job fairly high on my list.
Emergency works can cover works related to urgent health, safety, or preservation issues. I've got young kids in a house without heating downstairs. Maybe this could apply? A genuinely believe the trapped damp is rotting my joists so keen to sort the panelling and get that room heated asap. I could for example go for surface mounted pipes hidden behind a vertical radiator meaning the only damage to the property would be two holes in the ceiling (many of which need repairing anyway).
Historic England seem pretty relaxed about such works: https://historicengland.org.uk/advice/your-home/improvement/installing-services/
"You can usually change and upgrade most building services without affecting what's unique about the building although if in doubt specialist advice should be sought. If that's the case, there's no need to get listed building consent. Listed building or conservation area status should help to ensure that proposed changes are thought through carefully, rather than preventing change."
I'm all in favour of the LBC process, but they do need to speak to me rather than just leaving me hanging.
