I am pointing and levelling(lime) this interior wall on my solid brick 1850s property, replacing a horrible sand cement mix and concrete render.
Ive removed a white plastic vent cover to find this black tube which would vent to outside if it weren't for the plastic bags put in to block it up(presumably to stop windy weather coming through).
The exterior vent it actually slightly out of line and you can see how the interior pipes are out of line with each other also.
My question is, should I just remove the pipe and brick up the space before my levelling coat, or is reinstating it with a closeable vent cover a good option?
Am I invited moisture into the wall, or out of it?
Thank you.
Thank you.
