EBudd
- East Midlands
Hello,
I'm looking to fill a few cracks in the first floor render of my 1930s, solid walled property.
I've been led to believe that by the 30s, due to the development of building methods and materials, the bricks of 1930s solid walled properties were often harder, and the mortar and render mix different, than that used in older period properties. I.e. the mortar might be a lime/cement mix, as the bricks certainly seem hard, and the render might also contain a mix of lime and cement.
I'm unsure as to when it was last painted, but the render overall is in good condition. If like to fill the cracks and then repaint in those areas. Or repaint the whole front face maybe.
I've been looking at Earles Masonry Paint, which claims to be suitable for heritage properties, solid walls, lime render etc. does anyone have any experience of using it?
Any recommendations for suitable filler would be appreciated too? It's hard to find solid, reliable info on properties of this period. Advice is either biased towards proper heritage properties or more modern cavity wall properties, whereas 30s solid walled properties seem to be somewhere in between in terms of suitable materials.
Have also attached an image of the house for reference.
Thanks in advance
www.earlespaint.co.uk
Thanks in advance
Earles Masonry Paint Tubs - Super White - Earles Paint
A highly durable, breathable mineral paint suitable for a wide range of masonry surfaces. Contains no plastics, polymers or chemicals.
