Dear All
Thinking of having woodburners installed in 2 ground floor rooms of semi detached property. The rooms in question have gas fires fitted and functional chimneys.
However both chimney breast show evidence of either water ingress from open top chimney pots or from salts causing condensation in the chimney breast
Gas fires have not been used in the property for about 4 years.
Questions (and apologies if they are naive):
1) Will the introduction of heat into the chimney stack and breast with woodburner use aggravate the salts and cause spreading of damp on chimney breast?
Chimney pots are squared types and will have cowls fitted to limit water ingress
2) If you have had a woodburner installed have you been, overall, pleased with heat output and do you feel the installation was worth it?
3) Probably a daft question but will the wood burner just keep the immediate room warm or has it the potential to warm the upper floors 1 and a stretch 2 warm as well provided the door to the room with woodburner is kept open?
thank you
thank you
