Looking for some advice following a recent shower leak in our Victorian house. We discovered water stains on the ceiling below, and a plumber has since identified and stopped the leak. A section of the shower wall was removed, revealing laths behind the plasterboard, and further investigation exposed the pipework and the party wall.
You can see from the photos that the previous owners appear to have built the shower out slightly from the party wall. The plumber has suggested removing this to tile right up against the wall to create more space. I explained that I think this was originally done to allow for ventilation and to avoid working directly off the party wall, so I’m unsure whether removing it is a good idea.
He’s also proposing to re-board the area using moisture-resistant plasterboard, though I’ve had others recommend cement board instead. I’m not sure whether to push back on this or go with his suggestion.
In an ideal world, I’d strip the tiles and limewash the walls to allow everything to breathe, but with two small children, we just need a functional shower again as the leak has caused quite a bit of stress.
Here’s the quote I’ve received for the proposed works:
Shower works
I’m also looking to improve ventilation, we have an extractor fan, but the bathroom window is fixed shut, which hasn’t helped with moisture.
Lastly, regarding the water stains on the ceiling below (lining paper over what I assume is lath and plaster), my plan was to let it dry out fully and then cover the stain. However, some have said this might not be the best approach.
Any thoughts on:
Shower works
- Remove current shower area
- Remove all tiles in the shower area as required
- Remove studwork in the shower area
- Re-batten and board where required
- Adapt waste where required for the new tray (to be installed on leg kit)
- Run new pipework up to the shower area and clip pipework
- Re-board areas in moisture plasterboard
- Tile the shower area and around the window
- Grout tiled works
- Install new shower valve and screen
- Silicone all worked areas
Any thoughts on:
- Whether the quote seems complete and appropriate
- Moisture board vs. cement board for an old house
- Whether to keep or remove the built-out section against the party wall
- The best way to deal with the ceiling stains
- Improving ventilation when the window can’t open
