Andrewm1981
Hello all.
I have spent some time browsing the forum after buying our house a couple of years ago, but I need a little advice and was hoping that someone may have some!
My wife and I bought our first home 3 years ago in South London. We always wanted a unique property, not another "box" and were over the moon when this house came up. The house is a former coaching house, but has had many uses over the time. The front half dates to 1509, whereas the rear extension is more 17th century. It's divided into two, over 3 floors, and the wall we have a problem with is the "end" of the house. The "end of the house" butts straight up against a small road (now closed) and then to a pub. There's about 3m in total between our house and the pub. The house is timber framed with no foundations, and bricks in between the timbers (from what we can see). The house does have some sway in it, and when we're on the top floor and bus goes past, we can certainly feel the house sway. Minor hairline cracks have appeared occasionally, but I think that's normal. It's the plaster cracking. It's literally the thinnest cracks you could imagine. I'm not massively bothered by these. on 2 or 3 occasions we have heard what sounds like gravel/rubble falling from the top floor to the bottom, "inbetween" the walls.It sounds like a small amount, maybe an eggcup full. It's a little unnerving.
Internally, the walls are vertical, and are mainly plasterboard over the loadbearing external wall. There is a small cut out of 1mx2m on the staircase as a feature, and the wall there seems vertical, which doesn't correspond to the wall outside which leans, implying that the outside may be leaning away from the internal "loadbearing" wall.
Hopefully, the pictures show the lean. From what I can measure, the wall in 50cm thick, and the lean of the outer wall is 11cm at it's maximum. It then goes back on itself, so that at the top of the 2nd floor its where it should be.
I did have a leaky roof, as is common with a double gabled roof. I had a leak, and also where the water ran into the down drain it poured over and down the wall. this is where the lean is at its worst. I'm thinking maybe water ingress had called some wood to expand and force the outer wall out? These problems have now been resolved.
The pictures should also show the large X ties, and also the 2 supporting beams that go from our house to the pub.
When I bought the house the surveyor identified the lean, but as there was no historical movement he didn't say too much more on the subject. There are no new cracks inside or outside that suggest current movement.
I guess I'm asking on here if, from your experience, it's worth worrying about. Obviously, without being here you can't be certain, but just your hunch. If I need to spend money then I will. I'm not sure how, Our household income isn't huge, and I've read some pretty scary numbers with regards to rebuilding an entire wall, numbers approaching £100K seem to bounce around. I certainly could not afford anything like that, but 10K to reinforce it somehow could be saved for and paid through a loan somehow. The house is listed, and in a conservation zone too!
I'm guessing (but am probably wrong) that the house was constructed of a timber frame, with bricks in between. Then at some later date and extra layer of "wall" has been added to the outside (what's leaning as it seems to be large and blocky, maybe 70x100xm. I hope that's the case!
So any advice, would be appreciated. Comments like "Don't worry, it's already be reinforced, and the house has been standing 500 years so it's highly unlikely to fall now" are great if they're true from your experience (Don't worry, I won't sue if you're wrong!). Comments like "Get out the house now, and spend £100K on a wall" would be an absolute horrific nightmare, and cause untold financial ruin, but if the alternative was to be in a collapsed house then it might be the right thing to hear. Somewhere inbetween....well, we'll see what the numbers are like!
Thanks in advance, and if you need any more info then I'm happy to supply!
Andrew
Andrew
