f-llewellyn
- Chesterfield
Hi there guys. Bought my first house a few months ago and am sorting some things out that I thought needed doing to the property.
Currently, the only airflow the bathroom has is a small windows that's deep inset into the wall so I thought I'd install an inline extractor fan through into the loft and out the side of the house. I decided to go from the inside, as the wall butts directly up to a narrow pavement and didn't want to have to hire scaffolding and get the necessary permissions to erect it.
Bought a core drill set, along with an SDS drill and got to work last night. After 3 hours, my wall looked like this:
Not sure if it was due to the type of stone, or the uneven cutting surface, or (most likely) my own ability. The drill would either bind up on the wall, or bounce around if I tried to go faster. I could only get it to grind against it extremely slowly. I did drill a pilot hole, but it wasn't much help.
Eventually I managed to get through by peppering the circumference and hitting it out. After pulling out all of the rubble I could, I was still left with some stones too big to be removed and a very uneven cutting surface the other side.
When trying to drill through the outer course, it was extremely tough and I doubt my core drill set will be of much use. I'm starting to think I'd be better off getting a professional core driller on the case as they'll likely do a far better job than me in far less time.
Does anyone have any advice?
