dandrew
If this topic has been discussed ad naseum before, I apologise, but if so perhaps someone could point me to the correct thread in the archives.
We are the new owners of an 1860 stone built house with cellars, whose features we are in the process of re-instating. We would like to use the cellars as habitable space, but unsurprisingly they are damp, being below ground. Moisture seems to be coming up through the floor, which looks like Yorkstone, because it is damp. This causes a green mould-like coating to grow on anything organic - wood, papers etc and the smell is starting to permeate the rooms that are above the cellars. A previous survey (not ours) advised the then owners to 'remove the under-drawing in order to improve air circulation'. Presumably under-drawing was lath and plaster that covered the joists, since the joists are now completely exposed.
So in order to a) dry out the cellar and b) abolish the smell it will be necessary to waterproof the cellar. Given that most (all ?) of the damp seems to emanate from the floor will it be necessary to pour a new concrete floor on top of a plastic damp-proof membrane? If so we would probably have to dig down to establish sufficient head-height to pass building regulations. Would it then be sufficient to dry line the walls with a waterproof membrane or would tanking (
) be needed ? Clearly if we prevent moisture from coming up through the floor it will have to go somewhere else, but where ?
Any information gratefully received.
Thanks, David
Thanks, David
