lukebasterfield
This is my first post, after having found this forum through looking for advice on old buildings!
We brought a new house back in February which is a conversion of old farm buildings, arranged in an L shape. One side of it, used to be a pig sty, and we had noticed some problems with what look like damp patches on some of the interior walls in this area. The walls are plasterboard straight onto original brick work (dot and dab), which was the dividing walls for the pig sty (and I imagine used to be exposed to the elements prior to the conversion), and only go up to about 6ft, and divide the internal space. Interestingly, all of the exterior walls seem fine.
We were advised that these damp patches are likely to have been caused by salts in the walls, probably due to the fact is used to house animals, and moisture in the area was being attracted to the plasterboard, and where the dabs have been placed, the salts have migrated to the surface of the plasterboard.
Based on this, I was expecting to pull the plasterboard off, attach a studded cavity membrane such as Oldroyd (which I was advised by a number of damp companies), and put plasterboard back on to stop any future salts migrating through to the plasterboard.
In addition, I was planning to put in some PIV ventialtion to increase airflow, to prevent any condensation build up that might be attracted to the walls (the property seems to be very airtight, with little airflow in this area), which I believed was causing the issue.
Anyway, I pulled off the plasterboard today on one wall, and was surprised at the sheer amount of salt on this internal wall. I was also concerned that at the bottom of the wall, it seems that a lot of the mortar is missing or has eroded away. The mortar higher up seems ok.
There is also evidence of a DPC having been injected at a lower level just below the floor slab, due to regular drill holes.
I am therefore now wondering what to do, if I am indeed doing the right thing with the membrane, and what I need to do about the gaps in the mortar of the walls. Could this be an issue with cement mortar having been used higher up perhaps? (I dont know that it has, just guessing) instead of lime mortar?
Obviously I dont want to pull the entire walls down if I can help it, and whilst only single storey, I think in places they support the roof beams.
Having just spent all our money on buying what we thought would be our dream forever home, I am trying to make all the necessary repairs myself DIY, but would appreciate any help/advice so I can make sure I am doing the right thing. Is plasterboard onto membrane the best way, or would a lime plaster straight onto the walls be better? What steps should I take to clean/prepare the walls due to the existing salt damage?
Thanks everyone in advance for any help/suggestions!
