& Clementine the cat
- Bedfordshire
I've been doing bits and pieces on the trench over the last few months and with the quarter brick edging added today it's just about there. I went for 30mm thick grating because there is a chance I might touch a corner with a car wheel, but otherwise copied Zebra
(the Fibregrid is excellent - thanks). It rests on a retaining wall on one side, and on the other there is a stainless steel support every 1m fixed to the ground with stainless studs which I might get around to resin fixing into the concrete
There is a pipe to the soakaway directly under the drain pipe. Otherwise the trench just channels water that drips off the wall. I''m getting better at brick laying.
