MatthewC
- Central/South England
I have an obvious damp problem with some ground along the side of my house which is higher than the tiled floor inside by about six inches. There is a concrete path about 20 inches away from the house wall (limestone rubble), and between the path and the wall is soil, which I have lowered by about six inches as a starter. Logically the original level of the ground was below the floor level by some way, so I reckon that the wall must continue far enough down to allow me to remove the soil and restore the ground level to somewhere below the floor level.
Today I tried to remove a shrub growing beside the wall*. Digging down beside the roots, I found lots of small limestone rocks and some slate, and about six inches below the floor level there are some flat, level rocks which I would guess indicate the start of the foundations so I haven't gone any further.
However, to the side of the roots I also found some slate which appears to have been carefully laid. It is two pieces of overlapping slate, parallel to the wall, which slope down away from the wall at about 45 degrees, starting at about 2 or 3 inches below the floor level, and ending just above the level of the "foundation" stones further along. I reckon the other slate I found was similarly placed but was mucked up by the roots (or my digging).
Question: Given that the slate appears to be deliberately placed as some sort of aid to drainage, is this use of slate usual?
If so, then I would think that it must confirm that the level of the top of the foundations as well, and so I can dig down to that level, can't I? (The house was built post 1830 as a school and had substantial modifications in the mid-1800s to be a pair of semis, and I think this bit is later.)
All constructive comments gratefully received. I would do a drawing but I'm not feeling artistic tonight...
Matthew
http://houseintheenchantedforest.blogspot.com/
* Outside, of course - The house is not that bad!
Matthew
