MatthewC
- Central/South England
Does anyone have experience of any sort of grass mesh or other reinforcement? I need to install something inconspicuous (and cheap!) on my front lawn to protect the grass where cars turn or are occasionally parked - in front of the bay window (sorry, it's in the shade in this picture).
I do know that the job needs to be done early in the spring, by which time the front lawn will look like a rugby pitch which has had pigs and chickens grazing on it, so I want to be ready in good time. I've researched things on line, from concrete blocks to plastic hexagons and wire mesh, and it's all quite confusing. Everything seems to be quite expensive to buy (like, more than carpet - I found some at £45/sq m!) and also a lot of it needs all sorts of sub-layers as well; I have no desire to excavate 45 cm down, and don't really see the need to do so for such light use. All I want to do is to stabilise the surface against the occasional car tyre
So, is there something sensible out there, which will do the job at a realistic price? Has anyone found any nice alternative or even a DIY solution? I only want to do about 12 sq metres.
Matthew
http://houseintheenchantedforest.blogspot.com/
Matthew
