Seanie_230
Hello All
I have been pulling up my floor bit by bit and repalcing it with a new solid floor as the existing floor is cut to peices.
i have hit a brick wall (literally)
if you look in the picture you will see that i have come accross the peice at the bottom of the stairs and this goes directly under the brick wall and carrys on.
i have tried to remove this so i can put in a new peice but it does not move.
what is the best way to do this, im sure one of you has foudn this before.
Many thanks
Many thanks
