If its lead flashing its usually 'stepped' and tied into the mortar bed of the bricks. You'd have to expose the brick under the render on the right side to do this. Sometimes you see it employed diagonally with mortar applied on the top edge. And sometimes instead of using lead flashing people just flaunch the junction with mortar, which appears to be what you have here. Its not so common these days.Evening all,
Can somebody advise what the hell i do with this. No wonder i was getting rain under the flat roof, looks a right mess. Can i just put lead flashing over the entire lump (whatever that actually is?
Regards
James
Is this method prone to leaking, we have qa annoying leak that seems be only at high winds. I'm thinking because the guttering is running into the roof, it's finding its way in, seems to be missing tiles. as others have suggested above.
