Londonterrace
Hi everyone,
I'm back for some more advice; this time on tackling the ruined front of my house, please. I've posted this before - my house (at the end of the terrace) and the neighbour:
(It has been painted and lost one set of prison bars since the streetview photo so is 5% less awful. Just 95% left to go!)
Underneath the paint is pebbledash.
Restoring the bay seems straightforward enough, if £££. I presume I need to get sash windows made, mullions and a sill cast, and a builder to put it together.
The upstairs is trickier. One option is to try and put it back as it would have been, which would probably look best. However, the bricks that would have been between the two sashes have presumably been lost (unless I'm lucky and they were used to brick up the gap where the sash above the door would have been...). Would any attempt at reclaimed bricks stick out like a sore thumb?
Also the big window, whilst hideous externally, is very nice to look out of whilst sitting in bed of a morning avoiding DIY.
I'm also nervous about whether pulling off the pebbledash will ruin the bricks beyond repair. The pebbledash doesn't seem to be causing any damp problems at the moment (although perhaps that will come as it fails..) so pulling it all off only to have to rerender in lime seems a shame and a huge expense.
And presumably if you remove render you always need to repoint afterwards?
So the other option I can think would be to keep the pebbledash and replace the upstairs window with a similar one, although taller (to match the height of the sashes next door) and a better match style-wise.
Any opinions/other options gratefully received!
Also, I can't really afford hardwood windows and would love to avoid plastic. I've seen a company advertising engineered softwood windows as more weather-resistant. Is this true? Is it mad to install pine windows?
It's very much not a posh neighbourhood so expensive windows and lime render are not going to be valued when we sell.
I'll be getting a new front door.
