Herefordhouse
- Hereford
Hi all,
Thank you in advance for the time on this thread. I'm currently looking into insulation solutions for my property. Its an 1860s sandstone home. 2 of the external walls are pebbledash render with masonry underneath and 2 are exposed sandstone. The current plan would be to do EWI for the two rendered walls - probably some form of EPS/Kingspan insulation with a rendered layer on-top. Then for the two sandstone walls a breathable IWI solution on the respective internal walls. I've seen there are several breathable solutions available such as insulated lime, wood fibre boards, diathonite etc.
My thinking is the walls that need to retain breathability have the correct methods applied, with a form of insulation, and then the other two walls have modern efficient insulation. But is it a sensible decision to do a mixed approach to the insulation (especially on a property of this age). Furthermore, i've seen that you can get an improvement in the insulative u values of your property using the older breathable methods. However, to gain decent u values, do you actually need to cake on the stuff. Is there a best practice method for cost vs efficiency vs space required for such walls.
One last question, on the internal walls, we will need to replaster a lot of these walls as well. Is it possible to just plaster these walls in the normal way, since there is no breathability requirement. Theoretically if this is the case then it would only be the external walls on two sides of the house where we would need to use lime plaster with x insulation solution.
Many thanks in advance, and any tips of any form would be greatly appreciated.
Many thanks,
Josh
Many thanks,
Josh
