Penners
- Suffolk, England
Our kitchen is lit with eight low-voltage downlighters - the kind that are recessed into the ceiling, with the transformers shoved into the ceiling cavity. Each 50W 12V halogen lamp is driven by an individual dimmable transformer, 20 - 60VA IP20 SELV (there is no dimmer in the circuit).
One of the lights has stopped working. The halogenlamp itself is fine (it shows a resistance-free circuit on an ohmeter). The leads from the transformer to the lamp are both fine (again, resistance-free). The mains feed to the primary side of the transformer is fine, but on the secondary side I'm getting only 1.5V. I'm therefore assuming that the transformer is kaput.
Rather than buying a new transformer, I'm considering fitting this particular ceiling hole with GU10 mains-voltage downlighter. I'm a bit anti-low-voltage, as I regard the transformer as just one more thing to go wrong.
That's the background - here's my question. Is there any technical reason why I should not put a mains-voltage lamp into this circuit, along with the seven transformers which drive low-voltage lamps? So far as I can see, the units will still constitute simply eight loads on the mains lighting circuit, and shouldn't make any difference. But am I missing anything?
All opinions and advice gratefully received.
