Appreciate any advice please.(photos attached)
I have a small Victorian terrace cottage with a kitchen added to back at some point in time 1930s? and a bathroom added to that in the 1960s. All part of kitchen/diner now.
Been having ongoing damp problems, tackled from the outside of the house (lower geode levels, gutters, leaks etc but still having issues. This weekend I lifted a laminate floorboard to find a swimming pool of water underneath. Ended up removing 6 layers of laminated floors, carpet, lino, cardboard, vinyl tiles etc etc all of which were sopping wet. I'm left with concrete floor in the old kitchen part with lots of black tacky glue from lino tiles and a lumpy concrete old hearth area. There is about a meter of quarry tiles in the centre, and in the old bathroom area hideous marble-type tiles about an inch thick, laying on compacted hardcore, with rough concrete smeared on top of most of them. A couple of places in the concrete area are broken and there is uneven brick below which is very soft and damp.
I know I need to leave it all to dry out before I do anything. Firstly how long do I leave it to dry assuming I've found the reason for the damp?
Can you advise what is the best thing to do next. Should I have the whole lot screeded over what now exists and lay some tiles/slates on that? If so with concrete or lime or what...? Have read lots about houses needing to breathe (although inside walls were plastered with gypsum and outside rendered before I moved here). Should I lift all the marble/quarry tiles found first though and drop the level down to hardcore? I will have to get professionals in to sort out when I've saved up although will do as much prep as I can.
